E-Books & Guides
Create Topic
Why are my SLS PA 12 3D prints so brittle?
Hello, community! I have recently printed functional prototypes for snap-fit components using SLS with PA 12. The parts need to withstand repeated flexing without breaking. I noticed that the parts I’ve recently printed seem unusually brittle compared to previous batches and tend to crack or snap even under moderate stress. I haven’t made any design changes or material swaps between batches. Could this brittleness be caused by processing parameters or material degradation? Thnaks
Solved by DanML
I see, then that is most likely the root cause of the issue, you need to mix in at least 50% fresh powder with SLS printers and 20% for MJF printers.
      Considering that you have not made any changes to the material or the design, it is indeed likely that some processing parameters or material degradation is the culprit. Are you using recycled powder in these recent prints and if so how much new powder do you usually mix in?
        DanML
        Yes I am using recycled powder, I don’t usually mix the new powder into the old powder, I usually take the old powder and just top it up with a small amount of new powder.
        Axl Hemmingway
      Another potential cause is moisture ingress. PA 12 (Nylon) readily absorbs moisture, especially if it’s in powder form, you need to store your powder in a completely dry environment.
        Alex Bolt
        If I have left the powder exposed to a humid environment how can I go about drying the material out? Can I use an oven?If I have left the powder exposed to a humid environment how can I go about drying the material out? Can I use an oven?If I have left the powder exposed to a humid environment how can I go about drying the material out? Can I use an oven?
        Axl Hemmingway
        The material can be dried provided it has not absorbed too much moisture. I would advise against putting it in an oven to dry, you will most likely cause the powder to melt and bond together. The safest is to dry small batches using a desiccant dryer.
Contact
c
Aug 25
May 05
