What is the impact of clear anodizing and chem film on die cast parts?
Hi, I have a project making use of aluminum A380 as the base material. I want to coat some of the parts with either type II or III clear anodizing and other parts with a chem finish. My questions are as follows; if I anodize the part, will the coating be visible? Secondly, if I go with a chem finish will this affect how well an adhesive can stick to the part? I am specifically looking at 3M’s DP125 or PU 8609 adhesives.
Title: How to build a smartphone from scratch (parts & assembly) Description: Hello, I want to build a smartphone from scratch as a learning project. Can you please provide: – A full list of required components (mainboard, display, battery, cameras, etc.) – Recommended models or compatible parts – Estimated prices for each part – Step-by-step instructions on how to assemble them I am a beginner but I have basic experience with phone repair. Thank you!
Title: How to build a smartphone from scratch (parts & assembly)Description:Hello, I want to build a smartphone from scratch as a learning project.Can you please provide:- A full list of required components (mainboard, display,... read more
May 05
Surface Finish
