1.0 mm thick 6061 T6 aluminum sheet
Hello, does anyone know information like the dielectric constant, impact/shock resistance, tensile strength or strength of a material like ‘1.0 mm thick 6061 T6 aluminum sheet’? or I can get the datasheet because I couldn’t find it
Automatically translated from: Türkçe
Solved by Dogushan Colak
Greetings, the 6061-T6 material is not dielectric due to its metallic nature. However, 6061-T6 materials show an average impact resistance of about 7-8 J. Their tensile strength can vary between 270-300MPa.
    • Hello, does anyone know information like the dielectric constant, impact/shock resistance, tensile strength or strength of a material like ‘1.0 mm thick 6061 T6 aluminum sheet’? or I can get the datasheet because I couldn’t find it
