    • N
SLA wall thickness issue for microfluidic channels
Hi, I created a 3D design for a small microfluidic part using SLA (Clear Resin) with internal channels ~0.4 mm wide and wall thickness around 0.5 mm. The function relies on optical inspection through... read more
c
Embossed vs. engraved text for outdoor molded parts
Hi there, I need to add a part number and recycling symbol on the surface of molded parts in PP GF20 for outdoor use. I initially planned to use engraved text for aesthetic reasons,... read more
T
Aug 08
Minimum hole diameter vs sheet thickness 316L
Hello, I would like to produce a stainless steel 316L bracket, 3 mm thick, cut by fiber laser. I need to include several small holes for drainage and fastening, and I’ve heard there might... read more
Aug 01
Ejector pin placement near snap-fit
I’m working on a small injection-molded housing for an automotive sensor, using PA6 GF30. There are two snap-fit arms inside (cantilever type), about 2 mm-thick walls. I’m not sure where to place the ejector... read more
T
5
556
Jul 18
Adding countersinks to formed stainless sheet metal
Hello, I'm working on a sheet metal enclosure (as in the image) that requires flush mounting for M6 countersunk screws. I need to add a countersink on a few holes, but the part is... read more
Jul 03
