H
MJF material with the best low-temp resistance
Hello, I need to produce a small housing component for an outdoor sensor unit. I thought MJF could be a good fit for prototyping and potentially low-volume production. The part needs to handle exposure... read more
Apr 15
Best material for vibration-dampers fan spacers
Help, I need to reduce vibrations transmitted to the enclosure and improve airflow efficiency for 3D-printed spacers for mounting cooling fans on an industrial control cabinet. These spacers need to provide some damping without... read more
Y
Coated fasteners for stainless steel in coastal environments
We need to create a stainless steel structure for outdoor use in a coastal environment, and corrosion is our primary concern. We're considering coated fasteners but need to understand whether thicker coatings provide adequate... read more
Mar 18
Aluminium 5083 stiff enough for electronic keyboard enclosure?
I’m working on an enclosure for a compact electronic keyboard system, including a weighted key mechanism, and have chosen Aluminium 5083 for all parts due to its corrosion resistance and machinability. My main concern... read more
Apr 15
Best injection molding plastic for plastic enclosure
Hi everyone, we’re talking about a snap-fit design for a small electronic enclosure that needs to be opened and closed frequently—about 20 cycles per week. The part should be injection molded, and I’m deciding... read more
V
Apr 16
