How to improve paint adhesion to plastic?
Hey guys! I’m having issues with paint adhering properly. I’m trying to improve the cosmetics on some moldings of a waterproof portable speaker housing molded in ABS. The paint peels off easily after drying. Can anyone suggest effective methods or techniques to enhance paint adhesion to plastic surfaces? Any specific primers or surface treatments that work well? Thanks!
Jan 30
Surface Finish
Dec 17
Dec 09
