What shore hardness for vibration dampening pads?
Hi all, I’m designing vibration-dampening pads for a small industrial machine. The pads need to isolate vibrations effectively without being too stiff, and the machine runs with moderate weight and speed. I’m looking at polyurethane and silicone as material options, but I’m unsure about the ideal Shore hardness for this application. What hardness range would you recommend for balancing flexibility and load-bearing capacity?
Title: How to build a smartphone from scratch (parts & assembly) Description: Hello, I want to build a smartphone from scratch as a learning project. Can you please provide: – A full list of required components (mainboard, display, battery, cameras, etc.) – Recommended models or compatible parts – Estimated prices for each part – Step-by-step instructions on how to assemble them I am a beginner but I have basic experience with phone repair. Thank you!
Title: How to build a smartphone from scratch (parts & assembly)Description:Hello, I want to build a smartphone from scratch as a learning project.Can you please provide:- A full list of required components (mainboard, display,... read more
May 05
Surface Finish
