ABS vs Polycarbonate: tolerances for grip sleeves?
Hello! I’m designing lightweight hiking poles and need to attach a plastic grip sleeve to an aluminum tube core. The grip has to stay super straight and centered along the pole for good balance and comfort. Has anyone worked with ABS or Polycarbonate for something like this? I’m curious about the kind of linearity and concentricity tolerances I can expect, especially after machining or any post-processing. Thanks.
May 05
2.4k
