Best layer height for lattice lamp design with PLA
Hi! I’m designing a lamp and exploring FDM 3D printing with PLA for the first time. The design includes both fine and textured finishes, and I’m trying to decide on the best approach to achieve the look and feel I want. For layer thickness, I’m torn between a finer finish and a coarser texture. I know 200 microns is a standard choice, but what would you recommend for balancing surface detail with print efficiency? Any ideas on the likely layer heights used in the examples?
