Hello, I need to produce a small housing component for an outdoor sensor unit. I thought MJF could be a good fit for prototyping and potentially low-volume production. The part needs to handle exposure to sub-zero temperatures (down to -20 °C) without becoming brittle while retaining a bit of flexibility for snap-fit assembly. Among the available MJF materials, which one offers the best low-temperature performance combined with slight ductility?
May 05
2.4k
