On Metal Protection
Hello,
I am making railings and wrought iron outdoors with S235 steel. The products will be electrostatically painted. What treatment is required for these products not to rust and the paint not to peel off for at least 25 years? I have heard that the paint peels off quickly in hot-dip galvanizing applications. Would sandblasting + primer + paint be enough? Or what type of paint and procedures should be applied on hot-dip galvanizing?
I wish you good work.
Sep 09
Title: How to build a smartphone from scratch (parts & assembly) Description: Hello, I want to build a smartphone from scratch as a learning project. Can you please provide: – A full list of required components (mainboard, display, battery, cameras, etc.) – Recommended models or compatible parts – Estimated prices for each part – Step-by-step instructions on how to assemble them I am a beginner but I have basic experience with phone repair. Thank you!
Title: How to build a smartphone from scratch (parts & assembly)Description:Hello, I want to build a smartphone from scratch as a learning project.Can you please provide:- A full list of required components (mainboard, display,... read more
May 05
2.3k
