Reducing stepping on slopes surfaces in 3D printing
Greetings! There is an issue with stepping on sloped surfaces in FDM prints, specifically at a 20° angle to the x/y plane using FDM technology. Parts require a smooth finish with minimal post-processing. Tried reducing the layer height, but the problem persists. Is there a way to further fix this issue beyond just lowering the layer height? Would changing the part orientation or using a different 3D printing technology help with surface quality in sloped areas? thanks
1. Product Photography:
3.0k
2.3k
2.4k
