Hi, i am designing a push-rod connection between a linear actuator and a vehicle brake pedal for a durability test setup. The actuator can apply 750 N, and the pedal rotates through its travel, so the actuator rod sees angular misalignment and dynamic loads. I’m looking to allow this angular change without overloading/wearing the actuator. For high-force pedal actuation like this, what joint or linkage approach works reliably?
Dec 29
2.4k
Nov 25
Hi! I’m working on a compact linear slide mechanism for a handheld inspection tool. The carriage rides between two vertical guide rails and has to remain laterally constrained while still moving smoothly along the... read more
Oct 15
