Best practices for dimensioning parallelism from a datum
Hi, how do you handle dimensioning parallelism for critical parts? I’m debating between using basic dimensions with profile tolerances vs. a combination of ± tolerance and parallelism control. What methods and standards do you rely on for ensuring accurate alignment? Any specific guidelines or best practices you follow in your workflow?
1.9k
2.7k
2.7k
Dec 23
