I’m designing a protective enclosure for an outdoor sensor unit in SolidWorks, and I need to estimate how much polyurethane coating I’ll need. When I use the Evaluate – Mass Properties tool, it seems to include all internal faces of the assembly, which throws off the paint calculation. Has anyone found a reliable way to get only the external, exposed surface area of an assembled part? Any workflow tips would be really helpful.
Thanks in advance!
      Thanks in advance!
    • F
      Just use the measure tool and select the surfaces you need. You can also color the surfaces in a special colour to keep the selection and select the surfaces at once by clicking on the color.
Sourcing Cad Designer
electric motor
Nov 10
4.3k
Jul 02
e
8.4k
Jul 03
