FDM finish options to smoothen the surface
Hi everyone, I’m planning to 3D print a part using FDM technology, but I’m concerned about the visible layer lines that typically appear on the surface. Does anyone have experience with effective techniques to achieve a smoother finish, such as sanding, chemical vapor polishing, or similar methods?
May 05
