Choosing laser, plasma or waterjet cutting for stainless steel components
Hi, what are the key factors to consider when choosing between laser, plasma and waterjet cutting for producing custom stainless steel components (1mm to 20mm thick) with a ±0.1mm precision requirement? Specifically, how do material type and thickness, edge quality and the ability to handle complex designs affect the decision? thank you
Scanning and Printing
Jul 17
2.7k
1.6k
