Is there a possibillity to make my handmade objects into aquaria? I need fulley transparent material UV resistant, no scratches very strong 1 meter in height, what kind of meterial would i need and proces…. Any thoughts somebody, cause these objects are made as a vase but in large format it could be an aquarium, right? Is the material watertight and not toxic for fish?
greetings Jules Hofman
1. Product Photography:
3.7k
4.5k
2.9k
1.6k
Dec 23
