Manufacturing in Germany
Hello,
Does Xometry support us in setting up a workshop in Germany and producing there?
    • Hello,
    • Hello Mr. Ebubekir,
      At Xometry, we do not offer this kind of support. However, if you set up a production facility in Germany, you could produce a test part for Xometry Europe and send it to our office in Ottobrunn. You could then become a part of the Xometry Europe production network.
      Thank you very much for your interest.
1. Product Photography:
3.6k
4.4k
2.8k
