Hi! I’m working on a shrink-fit joint where a thin-walled 304 stainless sleeve is installed into a bored pocket in a much larger 4140 steel housing. The sleeve carries only light axial loads, but I want to size the interference so the hoop stress doesn’t crush or ovalise it. Most interference-fit guidance assumes shaft-and-hub geometry, which doesn’t translate well to a thin liner.
How do you estimate hoop stress for a thin sleeve-in-bore to pick a safe fit?
1.5k
1.6k
Mar 16
2.3k
Nov 25
Hi! I’m working on a compact linear slide mechanism for a handheld inspection tool. The carriage rides between two vertical guide rails and has to remain laterally constrained while still moving smoothly along the... read more
Sep 30
Slim linear guide for precise lab automation stage
I’m designing a compact linear stage for a lab automation setup, used to move a microplate (about 300 grams) precisely along a 150 mm travel. The system needs to achieve repeatability under ±0.05 mm... read more
2.0k
Sep 02
