en – EU
Türkiye Türkiye
United Kingdom United Kingdom
Global Global
DFM check: Is this part a "nightmare" to machine?
Hi! Designing a custom housing for a prototype. I’ve got features on all six sides, and I’m realizing this is going to need a ton of CNC setups. In your experience, is it better to design for manufacturing by splitting the part into two bolted components, or does the extra assembly time usually cancel out the savings from fewer CNC setups? What’s the “rule of thumb” for when a part becomes too complex for a single block?
W
12
125
Mar 16
Dec 23
