Community
Share your experiences, thoughts and seek advice in manufacturing. Create your own topics for discussion, ask questions, and participate in conversations.
Latest Top Categories
sizing holes in sheet metal to receive PEM inserts
Hello all,Xometry's own design guidelines state that when PEM self clinching thread inserts are desired, one should refer to the insert manufacturer's design guidelines.The datasheet for the insert I'm interested in calls for a... read more
n
Sep 16
Contact
Good day, I have been trying to receive the materials I paid for, for several days now. It's impossible to speak with anyone who can provide a serious and reliable update. The service is... read more
c
Aug 25
Scanning and Printing
Good day, I have a plastic component that I would like you to scan and reproduce in metallic material. Could you tell me if I can send you the plastic component for evaluation? Thank... read more
Jul 17
Is there a possibillity to make my handmade objects into aquaria? I need fulley transparent material UV resistant, no scratches very strong 1 meter in height, what kind of meterial would i need and... read more
Welding
Good afternoon,Does Xometry perform welding work such as sealing the folds of a box-shaped design?Can Xometry weld a nut, for example an aluminum DIN934, onto an aluminum sheet?Best regards read more
Selection of Bending Method in Sheet Metal Bends and Sheet Metal Unfolding
I want to design and manufacture a bent sheet metal part in the most accurate way possible. Once the design of the part is finished, I flatten the sheet, get a DXF file, and... read more
Hello, we have this small tool used to loosen/tighten a metal slotted ferrule. The teeth of the tool engage with the slots in the ends of the ferrule and torque is applied to tighten... read more
Sourcing Cad Designer
Artist doing a small run of a frame. Have spec would like to make via this site was hoping the community could point me in the direction of someone who can help prepare files... read more
